Home > Maintenance & Mods (L322) > intermittent power steering issue |
bebechoon Member Since: 22 Apr 2014 Location: In ze middle of Frainsch nul part Posts: 454 |
You don’t also have an intermittent fault in unlocking the back doors (and fuel trap) do you by any chance? I do (2005MY) and when that occurs I also have a problem with the steering being stiff too. Restarting generally sorts it all out.
7th Nov 2015 9:32am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8193 |
It amases me how garages think... the Range Rover has a wading depth higher than the bottom of the drive belt so it was made to run submersed in water without slipping.. mine has been feet deep without issues...
7th Nov 2015 1:31pm |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
When I first had my 4.4 it had intermittent power steering issues (along with a few others) eventually replaced the battery and after that it felt and drove like a different car
8th Nov 2015 11:36am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
As Pete said the Servotronic valve on the steering rack is a common fail, also the wiring is not too hot, could be a corroded plug, or it could be the BCM under the passenger seat has had a bath and is not playing ball anymore.
8th Nov 2015 12:21pm |
rangerover57 Member Since: 26 Mar 2014 Location: Bath Posts: 2 |
Hi all - and thank you for all your input. Yes! I do also have an issue with the rear door locks and the tailgate lock. So much of this seems to be making sense.
8th Nov 2015 5:24pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
You need a new BCM module, your unit and the relays inside the unit are failing that is what is causing your problems with the power steering and your locking of the rear doors.
9th Nov 2015 9:24pm |
Gloopy Member Since: 07 Feb 2017 Location: Oxford Posts: 5 |
I can't comment on the solution but I can confirm that on my 4.4l petrol, 2005, the power steering fails whenever I can't open the rear doors. The link is undeniable. I find it irritating but not enough to fork out for a repair. |
26th Feb 2017 9:10am |
I too found it irritating, so much so that I ended up buying and fitting a new BCM (see my thread- in the wiki - http://www.fullfatrr.com/forum/topic40009.html) At the time the cost was a tad under £200 from Dan.
26th Feb 2017 9:28am |
