Home > Maintenance & Mods (L322) > intermittent power steering issue
rangerover57
Hi - I have a 2004 4.4 V8 with LPG. For some time, the power steering has intermittently failed on start-up. I had the local LR specialist look at it and they changed the water pump, suggesting it was leaking and water from it was allowing the belt to the steering pump to slip. However, this has made no difference, apart from to the size of my overdraft!
Works most of the time, and when it doesn't, an engine restart sometimes kicks it back into life. Any ideas please?
Post #355652 7th Nov 2015 9:58am
bebechoon
France
You don’t also have an intermittent fault in unlocking the back doors (and fuel trap) do you by any chance? I do (2005MY) and when that occurs I also have a problem with the steering being stiff too. Restarting generally sorts it all out.
If this is your problem, it is apparently a not-unknown issue. I have read that the close proximity of the rear door locking and power steering signals on the BCM is the source of this particular problem. A new BCM is supposed to be the permanent solution to that but I haven’t (yet) gone down that route. See http://www.rangerovers.net/forum/6-range-r...nlock.html and for the article referred to http://www.fixya.com/cars/t5987413-rr_l322_4_2_s_c_november.
There again, this may be of no help to you, in which case – sorry! Big Cry It's "bébéchoon", ackcherly, with accents. 'Steve' to my chums.
20 years ownership of Solihull products, ALL GONE NOW, sniff!
Current motor: Suzuki S-Cross 4WD auto, 1.4 petrol. Oh so reliable! 7 years now and no problems. Oh, all right then, a leaking shocker replaced under guarantee.
Previous:
TD6 HSE L322 Auto FF
2.5 TDi 4-door Classic
Disco II
And my 1st Rangie: in 1995, a 2-door VM 2.5 diesel Classic
Not to mention the Lada Niva before those. (I said not to mention it!)
Post #355657 7th Nov 2015 10:32am
It amases me how garages think... the Range Rover has a wading depth higher than the bottom of the drive belt so it was made to run submersed in water without slipping.. mine has been feet deep without issues...
It could be the Servotronic Valve, a well known weak spot... do a search on here for more info...
Welcome to the Forum... Thumbs Up Pete
Post #355711 7th Nov 2015 2:31pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
When I first had my 4.4 it had intermittent power steering issues (along with a few others) eventually replaced the battery and after that it felt and drove like a different car
Battery was tested a number of times and showed ok ,but after it was changed no more PAS problems
Post #355838 8th Nov 2015 12:36pm
miggit
As Pete said the Servotronic valve on the steering rack is a common fail, also the wiring is not too hot, could be a corroded plug, or it could be the BCM under the passenger seat has had a bath and is not playing ball anymore.
1 Check that its dry under the seat
2 find the valve, behind the plastic wheel arch, drives side, and check the plug is not corroded, if it is some contact cleaner from Maplins, and the like, might cure it
3 if they are all good then it's more than likely the servotronic valve its' self
Good Luck Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #355847 8th Nov 2015 1:21pm
rangerover57
Hi all - and thank you for all your input. Yes! I do also have an issue with the rear door locks and the tailgate lock. So much of this seems to be making sense.
Will be looking to try some of your ideas/solutions over the next week or so and will let you know how it progresses. Much appreciated Cool
Post #355888 8th Nov 2015 6:24pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
You need a new BCM module, your unit and the relays inside the unit are failing that is what is causing your problems with the power steering and your locking of the rear doors.
Around £200 from Dan for a new one then it will just need programming
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos âžž YouTube.com/RangeRoverOwner
Post #356021 9th Nov 2015 10:24pm
Gloopy
United Kingdom 2005 Range Rover Westminster 4.4 V8 Java Black
I can't comment on the solution but I can confirm that on my 4.4l petrol, 2005, the power steering fails whenever I can't open the rear doors. The link is undeniable. I find it irritating but not enough to fork out for a repair.
Post #429233 26th Feb 2017 10:10am
bebechoon
France
I too found it irritating, so much so that I ended up buying and fitting a new BCM (see my thread- in the wiki - http://www.fullfatrr.com/forum/topic40009.html) At the time the cost was a tad under £200 from Dan.
Problems solved ... and as a bonus it also seems to have fixed my intermittent rear parking sensor problems too!
Previous:
Disco II
Post #429235 26th Feb 2017 10:28am
