Home > In Car Electronics (L322) > Newbie owner electrical question.
welderman
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Question about piggy back fuses.
Do you need to use the same size fuse your piggy back fuse holder is using. ie 15amp / 15 amp. or can you mix. ie 15 amp / 10 amp. ?
Also on a 2011 vogue which would be a switched live to pull off ?
Thanks Joe
Post #355590 6th Nov 2015 12:18pm
You fit the fuse you have removed from the fuseboard into the correct slot in the Piggy back. You can then fit any size of fuse you like in the fuse slot that serves your new accessory circuit as long as the selected fuse is adequate for your accessory wiring.
Post #355591 6th Nov 2015 12:21pm
welderman
that will do me fella, cheers
Post #355592 6th Nov 2015 12:27pm
