Home > Technical (L322) > Help with windscreen scuttle panel removal
webber
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Hi all,
I've got a cracked windscreen that needs to be replaced, the glass company came out and unbolted the wiper arms but couldn't remove the Part shown in my attached picture. They say they need to remove this before they can remove the scuttle panel. They tried a puller tool apparently and broke the tool so have said they can't do the screen replacement until I get it removed.
Any ideas how this comes off? Does it pull off, screw off or something else?
Car is a MY2010, not sure if they changed between model years at all.
Thanks
Adam
Post #355357 4th Nov 2015 8:52pm
It needs to be pulled off, with a puller tool, maybe some judicious use of the two hammer method, with squirts of WD40 (other lubricants are available) as well to help break the seal, last option is heat but don't melt the plastic!
A ball joint puller should do the job .
Post #355366 4th Nov 2015 9:24pm
webber
Great, thanks for the quick reply. I thought that was probably the case but wanted to check before I go buy a proper puller to do the job Thumbs Up
Post #355370 4th Nov 2015 9:46pm
Wants a shock to dislodge it sir... Thumbs Up
Post #355373 4th Nov 2015 9:52pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Strange, we had our windscreen replaced earlier this year by autoglass and they had all the correct tools to remove that part from the taper.
From memory it was a sort of ball joint puller they used.
Post #355382 4th Nov 2015 10:29pm
webber
I wasn't sure if I could give it a whack as I didn't want to damage the mechanism but I think I'll give that a go.
Paul - the insurance sent a company called auto windscreens instead, I wasn't there myself but spoke to the guy on the phone and he says he used his wiper puller tool like usual and it snapped it as its on so tight, so he told me I have to get it sorted myself before they come do the glass
Post #355385 4th Nov 2015 10:36pm
Thats a poor company then!
I personally would call the Insurers tomorrow and insist it goes to a LR dealer for replacement!!!
What would they expect my 74yr old mother to do? so he told me I have to get it sorted myself before they come do the glass THAT IS 100% UNACCEPTABLE!!! and for that reason alone, the man would not be returning! What will he nause up next!!!
Post #355386 4th Nov 2015 10:42pm
PaulTyrer
Would a penetrating oil work better than wd40?
Just read this.
'And if you don't mind a little mixology, try concocting a homemade cocktail of automatic transmission fluid combined 1:1 with acetone, which can be as much as four times—repeat, four times—as effective as any other product.'
Edit. Agree with Craig, they are the experts at screen replacement so should have the necessary equipment, as my dad always told me 'a bad workman always blames his tools'!
Post #355387 4th Nov 2015 10:43pm
What, like telling it how much a screen costs.... Rolling with laughter Rolling with laughter sorry
I'm with Craig, that is a fundamental part of changing a screen and will be done on most cars, if they can't get that off you don't want them doing anything else... Thumbs Up Pete
Post #355412 5th Nov 2015 12:38am
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Just read this.
Be careful the acetone does not destroy the plastic or paintwork.
I have recently found PlusGas to be the answer for seized items. Good reviews on Amazon Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #355421 5th Nov 2015 8:55am
acrr1
United Kingdom 2002 Range Rover Vogue Td6 Oslo Blue
+1 for Plusgas (and comments about finding a different fitter!)
Post #355439 5th Nov 2015 10:21am
webber
Thanks for the advice everyone, I managed to get it off with a £11 puller and some wd40 so not sure how the windscreen company found it so hard.
I'll be complaining, not sure if my insurance company will let me go elsewhere but I'll try!
Cheers
Adam
Post #355539 5th Nov 2015 10:36pm
Its your car sir!
If they sent two 10yr olds on bicycles to fit it, would you let them? Obviously not! So, stand your ground sir... ITS YOUR PRIDE & JOY!!!
Post #355543 5th Nov 2015 10:41pm
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
A good windscreen company certainly should not be baffled by this, have they never fitted a screen to a RR before Rolling Eyes Its not like its a rare car now is it Whistle
Post #355587 6th Nov 2015 11:07am
