![]() | Home > Technical (L322) > So I fitted the compressor kit and.... |
Brian Member Since: 06 Dec 2014 Location: Northern Ireland Posts: 138 ![]() ![]() |
I'd the garage reset the computer for me the other day and decided to put the kit in yesterday - put everything back together again and all was ok and then I decided to test it and *bong* air suspension inactive. Went out this morning to find the back sitting right down and after starting it nothing happened and it just sat there - I assume that it needs the computer to "reset" but I don't want to drive it like that so I've asked my mechanic to come over and put the computer on it - has anyone else had that or am I likely to be looking at something else? |
So far when clearing codes it goes back to 116 not enough pressure but no other error codes - and I cant hear the pump so I assume it's something daft I have done (like break it) I'll start at the beginning and pull it all out again and go over the steps to see if I did anything including meter the plugs to check for power and see what the story is now.... But first, tea. |
Check the fuse and then could be the pump motor has been over worked and fried.
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
^^----"But first, tea."
Yes tea is very important |
Update:
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
Mine logs a fault in the LCM (as well as the EAS) but it doesn't stop it working and doesn't bong up a fault...
Double checked the connections myself after noticing that my compressor did not have the multi-plug inside it, the wires went direct from the compressor, out the top of the tank/holder and onto the multi-plug in the boot |
30mph max only comes on when you get near 30mph as a warning it will drop if you continue...
I've used it recently and the hill descent as well |
