Home > Technical (L322) > Idle sppeed
PicnicSteve
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Idle sppeed
Evening everybody , going to Cornwall on Saturday now all of a sudden TD V8 vogue sounds like it is ticking over a little fast.
Can anybody tell me what the correct speed should be..... Hopefully it's me getting a little paranoid
Cheers
Post #344779 27th Aug 2015 4:33pm
700-750 rpm ... ... - .- -.
Post #344780 27th Aug 2015 4:38pm
PicnicSteve
Many thanks Stan, I'm running at just under 700 so all ok must be me getting twitchy for the 350 mile journey on Saturday morning.feel happy now.
Appreciate your reply
Steve
Post #344783 27th Aug 2015 4:47pm
Thumbs Up ... - .- -.
Post #344798 27th Aug 2015 6:14pm
Pvw10
United Kingdom 2014 Range Rover Vogue SE SDV8 Firenze Red
Can you lower this manually or is it a dealer option?
Post #355347 4th Nov 2015 7:47pm
It's not adjustable by anyone, it's set by the engine ECU, if it's wrong there is a fault... Pete
Post #355356 4th Nov 2015 8:52pm
Pvw10
Cheers Pete, just purely out of interest
Thanks
Paul
Post #355358 4th Nov 2015 8:55pm
Thumbs Up Pete
Post #355360 4th Nov 2015 8:58pm
fisha
You don't really want it to go lower. Each pulse of a cylinder igniting even at idle creates a large pulse of torque down through the engine, (cause the crank will have lost rotation speed between pulses) making it twist and shake. So it will try to twist on its mounts and then return to original position on each pulse. Lowering idle speed to allowing that would vastly increase the vibration.
But if you then have it such that the next cylinder pulse comesquicker or before it can settle back, then it will stabilise on the mounts and be smoother.
Explains why v8s sound and feel smoother than straight 4 blocks, esp at idle. V8 or else ...
Post #355391 4th Nov 2015 10:53pm
