![]() | Home > Technical (L322) > Idle sppeed |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35490 ![]() ![]() |
700-750 rpm ... ... - .- -.
PicnicSteve Member Since: 01 Jun 2015 Location: Lincolnshire Posts: 30 ![]() ![]() ![]() |
Many thanks Stan, I'm running at just under 700 so all ok must be me getting twitchy for the 350 mile journey on Saturday morning.feel happy now.
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 ![]() ![]() ![]() |
Can you lower this manually or is it a dealer option? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
It's not adjustable by anyone, it's set by the engine ECU, if it's wrong there is a fault... Pete
Cheers Pete, just purely out of interest
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1416 ![]() ![]() |
You don't really want it to go lower. Each pulse of a cylinder igniting even at idle creates a large pulse of torque down through the engine, (cause the crank will have lost rotation speed between pulses) making it twist and shake. So it will try to twist on its mounts and then return to original position on each pulse. Lowering idle speed to allowing that would vastly increase the vibration.
