Home > Technical (L322) > Noticing black smoke when accelerating |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3838 |
The car seems to be performing OK but when I accelerate and it kicks down there is a cloud of black smoke behind me. This isn't foot to the floor type acceleration but just enough to initiate kick down.
10th Feb 2014 4:48pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35419 |
i've always been told to floor it a few times to get rid of the carbon, dunno if it works or not.. |
10th Feb 2014 5:06pm |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
You could check the two big turbo hoses at the front and top of the engine - one of mine developed as split and caused similar smoking 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car! |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 |
That's why it's called dieseasal! |
10th Feb 2014 7:40pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7958 |
More details here |
10th Feb 2014 8:54pm |
I do get "engine System Failure" sometimes at start up but just put it down to low battery. Geoff |
10th Feb 2014 9:07pm |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Check your hoses to be sure could be low battery as you suggest. Present :2008 TDV8 HSE
10th Feb 2014 9:50pm |
At start up - it is probably battery related
10th Feb 2014 10:11pm |
Failing that check one of your tail pipes for a banana Present :2008 TDV8 HSE
10th Feb 2014 10:54pm |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
You wouldn't get any smoke if you had a DPF - I don't think a 2007 TDV8 has one (a 2008 certainly doesn't).
11th Feb 2014 8:05am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Geoff, you don't get a DPF until 2011 (ish) sir
11th Feb 2014 8:14am |
godot Member Since: 03 Nov 2015 Location: London Posts: 2 |
Hi
3rd Nov 2015 10:07pm |
Ouch !
3rd Nov 2015 10:21pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
A good argument for fitting a EGT gauge to measure temps at each exhaust manifold or dump pipe. ______________________________
4th Nov 2015 2:07am |
