![]() | Home > General (L405) > InControl or Out of Control? |
Doodle Member Since: 02 Nov 2013 Location: Midlands Posts: 127 ![]() ![]() |
I have remote App. on phone and IPad.
modbarra Member Since: 28 Mar 2009 Location: northampton Posts: 237 ![]() ![]() ![]() |
Ditto..... No issues |
Charlyfarly Member Since: 26 Jun 2015 Location: Warwickshire Posts: 210 ![]() ![]() ![]() |
I too have a problem with the InControl app.
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 ![]() ![]() |
I too have the app and the only issue I have is the length of time it takes to actually connect and update the info when I use it. It gets to the stage of giving me a warning saying it is taking longer than expected to and there is a network delay. Is this anybody else's experience? Agueroooooooooo. 93-20
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
Yes, I typically get warnings that it is taking more time than expected to contact the vehicle but I put that down to a poor signal where it is parked. |
I don't think it can be a weak signal as mine is parked about 20 ft from me now and it always shows the same warning. I don't think it's a fault I just think it must take that amount of time to check and convey all the info but iam more than ready to be proved wrong. |
Paddywhite Member Since: 20 Sep 2015 Location: Birmingham Posts: 5 ![]() ![]() |
My new L405 was fine for the first 20 days then it went in for some illuminated tread plates to be fitted and they had to connect into the wiring loom, this caused a glitch with the app stating constantly that my car was unlocked when it clearly was. Investigation showed that the connectors to the new wiring were not fully home and the sensors were not reading correctly. May be worth keeping an eye on it so see if this may be a problem. The dealership knew straight away where to go look first when I explained the situation with the false readings on the App. |
orbtar Member Since: 07 Aug 2007 Location: Suffolk Posts: 22 ![]() ![]() ![]() |
I haven't bothered with InControl for the last two cars, it was a right pain trying to register a second car on the system with it saying I was already registered so I gave up. 2015 RR SDV8 Vogue SE
So, changed internet provider from Orange (EE) to BT.
