![]() | Home > Technical (L322) > Rear Prop shaft studs replacement |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8374 ![]() ![]() ![]() |
Minimum grade 8.8 high tensile bolts that fit the holes, nylock nuts, flat washers. You want them long enough to fit through, get a washer each side and the nut on with a thread or two sticking out. Bolts are measured along the thin part of the bolt, WITHOUT the depth of the head,
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
pete, we may have to start calling you 'Hammer Haylands'
Pete testing his new hammer
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 ![]() ![]() ![]() |
Well sourced a new prop with the studs pressed in so Will just replace like for like but do need new nuts. Anyone know the size? Can't find this on rave or workshop manual.
Take one of the old studs to B&Q, Halfords etc and try some out, strangely nuts aren't rated, unlike bolts, personally I always use stainless ones when replacing them...
I think that's what I'll do, cheers for the help.
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2665 ![]() ![]() |
That's some hammer collection, do you name them? |
I doff my hat to that impressive hammer display! All shiny, and loved, with particular stories to tell. Even to the useful baker's dozen toothbrush tub below. Did you used to practice a little panel beating back in the day Pete? . With no doubt a drawer full of shiny dollies to work those hammers in perfect unison. Or even beechwood lead loading dollies? And sausage fingers? from a happy life of tool-time! ![]() |
That's not really my garage... |
