Home > Technical (L322) > Rear Prop shaft studs replacement
tomthevet
Scotland 2005 Range Rover Vogue Td6 Tonga Green
Hi all
I am in process of replacing the rear propshaft on a 2002 Td6 but want to replace the pressed in studs holding the rear end to the diff with bolts and nuts as the studs were just rotating with the nuts necessitating cutting the nuts off to remove them. Can anyone tell me what bolts and nuts to use? I cant find any info.
Also as an aside though the front end came away easily the rear end seems to be seized well onto the diff. Anyone have any tips to get it to shift? I am assuming it is just mated up to the flange on the diff so a pry should eventually free it off?
Cheers
T
Post #354662 29th Oct 2015 11:07pm
Minimum grade 8.8 high tensile bolts that fit the holes, nylock nuts, flat washers. You want them long enough to fit through, get a washer each side and the nut on with a thread or two sticking out. Bolts are measured along the thin part of the bolt, WITHOUT the depth of the head,
When you have unbolted the rear prop just give it a whack with a hammer, it'll be rusted in place... Pete
Post #354669 29th Oct 2015 11:58pm
johnboyairey
pete, we may have to start calling you 'Hammer Haylands'
you do like a good hammer!
Post #354670 30th Oct 2015 12:18am
Pete testing his new hammer
 2008 MY Supercharged
Post #354672 30th Oct 2015 12:36am
tomthevet
Well sourced a new prop with the studs pressed in so Will just replace like for like but do need new nuts. Anyone know the size? Can't find this on rave or workshop manual.
T
Post #354679 30th Oct 2015 7:52am
Take one of the old studs to B&Q, Halfords etc and try some out, strangely nuts aren't rated, unlike bolts, personally I always use stainless ones when replacing them...
Johnboyairey and axle, you haven't seen the rack in my garage then..... Rolling with laughter
 Pete
Post #354695 30th Oct 2015 10:16am
tomthevet
I think that's what I'll do, cheers for the help.
T
Post #354706 30th Oct 2015 12:26pm
Mr Tee
That's some hammer collection, do you name them? Mr. Green
Which one's your favourite?
Post #354709 30th Oct 2015 1:16pm
Post #354712 30th Oct 2015 1:40pm
johnboyairey
I doff my hat to that impressive hammer display! All shiny, and loved, with particular stories to tell. Even to the useful baker's dozen toothbrush tub below. Did you used to practice a little panel beating back in the day Pete? . With no doubt a drawer full of shiny dollies to work those hammers in perfect unison. Or even beechwood lead loading dollies?
And sausage fingers? from a happy life of tool-time!
Post #354755 31st Oct 2015 12:07am
That's not really my garage... Rolling Eyes
It is the one thing that experience teaches you when you do a lot yourself on cars.... hit it harder, get a bigger pry bar, get it glowing red hot... etc etc
When we start out we think it's a delicate piece of machinery, but sometimes you have to show it who's boss.... Thumbs Up Pete
Post #354758 31st Oct 2015 12:47am
