Home > Maintenance & Mods (L322) > Lower tailgate support bolt detached
No signs of corrosion on my 2012 Vogue yet but worryingly the bolt securing one of the lower tailgate supports has pulled through its housing in the rear bulkhead,without being subjected to any unusual strain The hole through which the bolt is fixed,is rusted around the edge just enough to have permitted this
I'm a year into my Approced Used Warranty and would be very interested hear of similar instances- and resolutions.Many thanks in anticipation.
Post #354510 28th Oct 2015 6:10pm
pld118
Wow Shocked have you taken/ will you be able to post a picture so that members can put it into context please?
Based on your post content, I'd be very surprised if you were unable to have this dealt with under warranty and will follow your post with interest Thumbs Up
Post #354512 28th Oct 2015 6:45pm
0949
I'll keep you in the picture-literally...
Post #354575 29th Oct 2015 9:35am
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
If Landrover can cite UK weather as a reason not to tackle corrosion nothing would surprise me Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #354578 29th Oct 2015 9:52am
johnboyairey
members/owners should check also, that these tailgate bolts are not un-doing themselves, as I found both of mine were a couple of turns out...its the slight rotation effect of the wires being folded, (I believe) that will undo a loose/or perhaps strained bolt. -only for the owner/guest to sit on said tailgate to change his/her boots, and in an instant, -offer his/her bulk to the mud!
if only to stop the embarrassment and 'hooting' of inevitable laughter! and spillage of the malt!
Post #354673 30th Oct 2015 12:55am
SMUTT
@JBA - good tip - will check mine - nothing worse than wasting a good whisky Howard
Post #354688 30th Oct 2015 9:14am
on the 06MY i drive often i have replaced both units at the rear and by god they were really rusted in place!! Glad the torx screw has gone for a better bolt design! I applied a load of grease to mine and then peeled the rubber back a little and shoved loads in there to to make sure it should push moisture away and they should last at least another 10years now FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #354692 30th Oct 2015 9:59am
0949
Lower tailgate bolt detached
Thanks for the comments everyone. Here's the image showing the rust which appears to have allowed the bolt to pull through. Bit underwhelming for a 2012 car dont you think? Will post warranty verdict in due course
Post #354984 2nd Nov 2015 11:04am
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
Shocked Shocked Shocked
Ouch
I'm always sitting on my lower tailgate!!!
One day......
Post #354985 2nd Nov 2015 11:58am
i knew that the straps rust but thats really nasty.. ... - .- -.
Post #354986 2nd Nov 2015 12:03pm
CS
Disappointing indeed. The 2012 vintage does seem poor for corrosion. If it was mine, I would be asking LR/its dealer whether this falls within the 6-year perforation warranty. Only Range Rovers since 1988
Post #354987 2nd Nov 2015 12:07pm
