Home > Technical (L322) > Rear heater is cold? |
Garyfax Member Since: 02 Feb 2015 Location: Halifax Posts: 124 |
Hi folks.
27th Oct 2015 7:07pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8320 |
You do know it has an adjuster for rear temp next to the outlet in the rear...
27th Oct 2015 7:18pm |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 611 |
Don't know about pre facelift cars but mime has a button bottom right of the centre console which enables / disables the rear heater controls. If you have the light on then the rear controls are active, otherwise they match one of the two front controls. Which one I don't know/can't remember...
27th Oct 2015 7:56pm |
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 441 |
We experience the same on our 07 ffrr - mostly cold air in the rear air vents, regardless of how I set the rear temperature adjustemt knob. If I turn on the rear AC with the "real AC knob" on the front panel, the rear air is a bit less cold, but far from as hot as it is at the front.
27th Oct 2015 9:49pm |
Thanks folks.
28th Oct 2015 7:02am |
IIRC its tied into the passnger heat setting as well so worth whacking that up and see if it makes a diff FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
28th Oct 2015 9:38am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35416 |
not tried this myself but would the front center horizontal dial that controls the center/side vent temperature also control the overall heat to the rear center vents...
28th Oct 2015 10:03am |
28th Oct 2015 10:11am |
From the manual,
28th Oct 2015 10:32am |
That's interesting.
29th Oct 2015 3:59pm |
Did you found out what caused the cold air in the rear vents? |
12th Nov 2015 10:54pm |
Unfortunately not. Still cold for passengers in the back. |
14th Nov 2015 4:46pm |
