Home > Maintenance & Mods (L322) > Fitting Supercharged exhaust backbox to earlier 4.4 V8
Josh Wyatt
United Kingdom 2014 Range Rover Vogue SE SDV8 Causeway Grey
Hello all!
A quick query! I have a 2003 4.4 in need of a replacement back box, I have an original Supercharged backbox from a '55' 06my. I know (or think) the exhaust mounts/hangers are in a different place, so you can't just fit the supercharged exhaust.
My question is, I assume the Westfalia tow bar armature for the 06my has the exhaust brackets in the correct place for the supercharged exhaust, and fitting this armature to the '03' would enable the box to be fitted? As I assume the only reason they're not compatible is because of the exhaust hangers? I've searched, and it does say the 02-05 and 06+ aren't compatible, but is this only because of the exhaust?
Or is there an easier way to do it? Bow down
Post #353994 24th Oct 2015 10:55pm
fisha
The brackets that bolt to the chassis look different, but remember a rubber hanger goes between the exhaust and the bracket. So it may be that you can leave your existing bracket in place, and the exhaust just connects using the rubber pieces as normal.
I would surprised if they changed where the arms of the exhaust box sat in relation to the chassis, so it may be possible. My SC isn't on the driveway at the moment, so can go out and look at the moment V8 or else ...
Post #354018 25th Oct 2015 9:12am
Josh Wyatt
Thank you Fisha. I think you're right, I'm sure there's someway of doing it.
I'll give it a go, and report back in case anyone needs to do the same!
Post #354152 25th Oct 2015 10:21pm
robbo770
Scotland 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
You need to get the brakes from a part of rear outer chassis supports if you put a towbar on,
Cut the brackets of with the exhaust supports and bolt on to the car via the front most mounting bolts Current vehicles
4.2 SC FFRR RSE 2010- facelift
Range Rover Evogue Dynamic Lux
Gone
Rejected RRS my14.5 nightmare
Disco B4 XXV convert
Freelander 06 SE
06 RFFRR 4.2 SC Vogue RSE
Audi A8 4.2Tdi Quattro (hated with a vengence!!)
54 FFRR 2005 model V8 4.4 Cobra Variant
53 Mitsubishi Shogun V6
Post #355983 9th Nov 2015 7:09pm
