Home > Technical (L322) > Coolant Leak near Alternator (V8) SOLVED |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
Thanks very much for the chain info. I remeber seeing an episode of "The Garage" where a FF came in and I think one of the mechanic broke the "brittle" chain guide - next day he had had enough and off back to UK - I got the impression no other mechanic really wanted to touch the FF so I have no doubt it is a big job!
23rd Oct 2015 10:44am |
Further to this - checked the alt bolts - all fine. Cleaned up liquid. Wiggled top hose fitting to alternator. Nothing. Came back about a minute later - small pool of coolant. Now wiggled conector again and BINGO - a tiny trickle following the alternator / housing seam down to the V gulley where it usually pools (as per original post)
24th Oct 2015 7:54pm |
Andra Member Since: 22 Sep 2015 Location: Scotland Posts: 62 |
Viton O rings available here for pennies http://simplybearings.co.uk/shop/Seals/c19/index.html |
25th Oct 2015 4:01pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8206 |
If the hose "O" rings are shot then it's time to replace the hose, the plastic the ends are made of gets hard and brittle over time and they will just fall apart... not worth bothering with.... Pete
25th Oct 2015 4:46pm |
Fair point about the hoses and plastic connectors replacement due to age but that may not always be the case because the old O rings compress and harden quickly even on hoses which were recently replaced . Some leaks will only happen when very cold and will seal when the system warms .
25th Oct 2015 5:09pm |
Thanks for all the advice. New hoses shall be order as you say not worth bothering.
25th Oct 2015 5:54pm |
New Rad Top Hose fitted today - so this effectively replaced the Alternator Connection O ring
31st Oct 2015 4:45pm |
Pete
31st Oct 2015 5:21pm |
@Haylands - No hammers were used in the fitting of this component.
31st Oct 2015 5:33pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
I thought that the hose connections were OK, and we were talking about the actual alternator to engine sealing o ring, that's about 6 inch diameter. However, the typical rad hoses and their o rings are a source of potential leaks.
31st Oct 2015 5:54pm |
SMUTT I warned all of that last year when I bought mine, it too was leaking from that spot and fell apart when touched, it's also in my build thread so you should have read it....!!!!
31st Oct 2015 6:25pm |
@JBA - Yes originally I thought it was the large O ring - but further checking (see post further up this page) turned out by flexing the connection on alternator it weeped slightly. But thanks for your help on checking alt bolts etc.
31st Oct 2015 6:36pm |
I'll let you off this time, now go and read all the old posts from everyone... Pete
31st Oct 2015 8:55pm |
