Home > Technical (L322) > Coolant Leak near Alternator (V8) SOLVED |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
21st Oct 2015 9:39am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8206 |
Yep, it sits in the water, it's a totally sealed unit obviously... try nipping up the bolts holding it in, if not sounds like a new seal...
21st Oct 2015 10:39am |
Hi Pete, thanks for the speedy advice as always.
21st Oct 2015 11:18am |
I'd get it done now if I were you, pretty easy job, worst bit is getting the fan off, I've got a home made tool for it.
21st Oct 2015 1:32pm |
@Haylands - thanks for the offer on the fan spanner - presently running without the fan anyway - easier to leave it off over winter and speeds up access when I have repairs to do - should that need ever arise with the FFRR
21st Oct 2015 7:19pm |
Starberg Member Since: 08 Jan 2015 Location: Karlskrona Posts: 70 |
You say you running your car without the viscofan SMUTT, how does that effect your cooling temperature? Is it safe to drive without the fan over the winter?
22nd Oct 2015 4:34am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Its safe to do so but! A, you need to make 100% sure your AC fan is working and you drive with your AC on, as this now becomes your emergency cooling if stuck in a traffic jam! & B, if the AC fan gives up the ghost... You have NO redundancy sir |
22nd Oct 2015 8:11am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
when tightening the bolts, just be carefull not to touch the red battery cable with the socket, or spanner, it will spark big time! do not overtighten, if you strip a tread on that housing, its a massive job to replace the front timing cover. if you take alternator out, use a bit of paint to mark one bolt hole to the corresponding bolt hole, as its easy to put it back in on 'out of position'
22nd Oct 2015 8:16am |
^Now there is a man with experience^... Great advice |
22nd Oct 2015 8:23am |
@Cam-Tech-Craig - thank you for the warning
22nd Oct 2015 9:01am |
Yep, they quote 10lbft for the alternator bolts, that's not very tight at all so don't go mad....
22nd Oct 2015 9:25am |
Yes, had to remove said front lower timing cover, to change the timing chain, (bought car with chain job required) yes its a massive job. and i removed alternator first. so yes, i know its heavy, and cumbersome. and how silly they have been to let you place it back in (i think) at any rotation, and it fits, so you think its right, till the leads dont reach. and i dropped a spanner after it was all ok, and it touched the red connection, and a few sparks blew out, -you do more damage to yourself getting out of the way. so just a dab of nail varnish over the two faces ensure it goes back same position. there is a write up i read a few days ago on repairing a failed alternator, but this doesnt mean yours needs repair, just resealing. -perhaps.
22nd Oct 2015 12:49pm |
@Haylands - 10lbft - that is light - thanks for pointing that out to me.
22nd Oct 2015 7:03pm |
Yes you can mine was a Bosch refurbished one, got it just before last xmas... Pete
22nd Oct 2015 7:41pm |
