Home > In Car Electronics (L322) > What's in my boot?
RSW
What's in my boot?
[img]Started to dig into my new 02 L322 now and looking in the boot I seam to have too many boxs for stuff compared to other photos I have seen here.
Can you tell me what does what?
Post #352938 18th Oct 2015 6:33pm
Well for a starter the patch panel with the 2 blue rca plugs is not a standard fit, might once have had a PlayStation or some sort of console fitted.
The big bluish silver box is a dvd changer, on top of that is the nav disc player, under them is the main amp. There is nothing that can't be fixed with a hammer😜😜
Post #352944 18th Oct 2015 7:05pm
mjdronfield
The unit on the far left that's silver and more stood on its end is the TCM or telephone control module. The little unit on top of the sat nav which has the cable with the purple end going to it is the Bluetooth antenna for the phone...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #352948 18th Oct 2015 7:27pm
TCM is Traffic Channel Management not telephone , there is a lot of stuff in there I don't recognise . What year and model is it?
Edit ; I see no fibre optic so it must be a BMW ere car , sorry pretty much clueless then Embarassed 2008 MY Supercharged
Post #352989 19th Oct 2015 12:54am
mjdronfield
The TCM is what bmw used before the ulf module. Land Rover were sold before the ulf came out, that's why you can retro fit a ulf to pair with your mobile from a later bmw, but the 50 pin cable has to be rewired. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #352993 19th Oct 2015 5:34am
RSW
It's 2002 L322 with RSE from new so the invoice says. Got a phone in the cubby but no Bluetooth. Can't get any TV so assume it's still analogue tuner. But still to many boxs
Post #352994 19th Oct 2015 5:36am
mjdronfield
The only extra boxes I can see are the DVDs player, up high under the sat nav, and the patch panel with the Rca female sockets on it.
The TVs unit has the blue and white plugs going to it, plus the 2 small antenna leads. The bm54 radio module is at the side of that, slightly lower, at the side of the spare wheel area, and the dsp is black and behind the TCM phone module.
Think that's it...... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #353153 19th Oct 2015 4:26pm
RSW
What is the box in front of the TV tuner then as I thought if I got the digital box then it would fit here?
Also not clear in the photo is a free small wire just above the TV box bit like the TV aerials, not sure where this should go?
There are actually 4 boxs behind the patch box, phone dspamp and?
Thanks for the help all
Post #353165 19th Oct 2015 6:04pm
Eric Cartman
Ireland 2010 Range Rover Autobiography TDV8 Santorini Black
the two boxes with the RCA connectors id say are video switches for each of the RSE screens, the cable plugged in is probably from the AV out from the TV tuner or dvd changer. leaving you the ability to connect 3 more sources to each screen
Post #353171 19th Oct 2015 6:45pm
mjdronfield
The BM54 radio module is in front of the TV unit. The one that's lower down. It actually contains the amps as well. The dsp is only a sound processor, not an amp, but it seems to be referred to as a dsp amp, so can be a bit confusing.
To the right of the tv unit in the pic, towards the back seats, you can see the edge of the sub woofer unit.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #353175 19th Oct 2015 7:08pm
RSW
Thought it was one box will look again when I get chance
Post #353198 19th Oct 2015 8:19pm
RSW
So do you think it's not original RSE?
Post #353202 19th Oct 2015 8:30pm
mjdronfield
Prob need to see a picture of the screen in the headrest to comment on that....
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #353205 19th Oct 2015 8:34pm
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
IIRC early factory RSE waasnt in the headrests but lower down in the seat back.
Post #353258 20th Oct 2015 8:41am
RSW
Post #353510 21st Oct 2015 5:56pm
