Home > Technical (L322) > 3.6 TDV8 air flow related problem |
L19 MUD Member Since: 02 Jun 2015 Location: Suffolk Posts: 167 |
Time to find them and pull them off, do you think a clean up might be enough to free it off? It does make sense for it to be that.
19th Oct 2015 3:51pm |
Stripped the air intake manifold off the top of the engine last night and inspected the throttle bodies, both move freely and move back smoothly to the fully open position, I think we can therefore rule that easy fix out (also have no throttle body related codes)
21st Oct 2015 9:25am |
Just to conclude this in case anyone has similar symptoms in the future
22nd Oct 2015 7:57am |
proser Member Since: 20 Jul 2015 Location: Stafford Posts: 452 |
when you say that the head of the EGR valve had come off can you explain more
24th Feb 2016 4:24pm |
The flat end of the valve that seals around the valve seat (they look like an exhaust/inlet valve) had come adrift from the stem of the valve. The stem is moved in and out by an electric motor controlled by the ECU
24th Feb 2016 4:48pm |
Thanks Regards
24th Feb 2016 10:27pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Well done. Any pics, how long to get EGR out? ______________________________
25th Feb 2016 12:08am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Could you see the problem with the EGR’s still in place with the pipework connected or did they have to be removed completely to diagnose the problem please? |
25th Feb 2016 8:32am |
Here is a picture which will hopefully make it clearer. There is no way of telling until the valve is removed (or at least disconnected from the exhaust end and tilted up)
25th Feb 2016 8:49am |
Thanks for the pic.
25th Feb 2016 9:06am |
Thanks. ______________________________
25th Feb 2016 9:39am |
Thank you for the clarification Mr Mud sir
25th Feb 2016 9:42am |
OtleyDominic Member Since: 01 Nov 2017 Location: Leeds Posts: 61 |
I am having a very similar challenge with my 4.4 tdv8 going into restricted performance. It is showing very similar codes relating to the maf and EGR! |
20th Jan 2018 9:06am |
