![]() | Home > In Car Electronics (L322) > Radio interference when rear screen heater switched on |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3873 ![]() ![]() ![]() |
The title says it all really, not much comes up with a search has anyone had similar I assume its earthing somewhere but where to start? Geoff |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8392 ![]() ![]() ![]() |
At a guess there will be an amplifier in the system that I would have thought would have a suppressor in it, maybe that has broken or come unplugged?? Pete
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35509 ![]() ![]() |
could be a bad earth or a break in the heater lines causing the interference...you can check this by switching on the rear window heater and passing the ariel of a portable radio across the window and see if there are any 'hot spots'... ... - .- -.
The rear window has been out to have the tailgate done, I think that will be my first port of call, body shop men do not make great auto electricians - although they did do a good job spraying the tailgate and the wing mirror |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 ![]() ![]() ![]() |
I had this after the dog scratched the rear window elements. I would think a damaged element is the most likely explanation for your problem.
OK now so hard to fault find however rear screen looks OK. Geoff |
