Home > Technical (L322) > L322 Wont Start, Clicking noise from behind dash |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Unfortunately it is definitely NOT the ignition switch then...
18th Oct 2015 11:21am |
NeilC Member Since: 01 Sep 2015 Location: Newcastle Upon Tyne Posts: 14 |
Pete,
18th Oct 2015 11:31am |
No problem, glad to help,
18th Oct 2015 11:39am |
There is an outside chance it's voltage related but I wouldn't think so as you haven't got any other faults shown and a low voltage sends everything crazy....!!! Pete
18th Oct 2015 11:53am |
A diagram would be much appreciated Pete whihc you have time.
18th Oct 2015 12:12pm |
Might just be worth disconnecting the battery, see how to do it properly in the WIKI if you haven't as it has an explosive disconnect, and then give it an overnight charge if you have a charger, just a trickle charge will do don't do it on full power or you will boil it to death....
18th Oct 2015 12:21pm |
Royston, Established its the steering rang lock with Petes help.
18th Oct 2015 12:24pm |
Thinking about this a colapsing curcuit would work with mine as I have removed the plunger in the ignition switch so mine will always get to ignition but won't crank, you can't get to ign live so may be able to do something with a timer relay...
18th Oct 2015 12:58pm |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 316 |
18th Oct 2015 1:31pm |
thansk for that Pete,
18th Oct 2015 1:42pm |
Uli, Did you try it with the solenoid removed, would it still work then....??
18th Oct 2015 1:48pm |
@Haylands, the solenoid has full function after cleaning with WD40, also you have to clean the white motor, he pushes the lock in and out, and the solenoid with his pin is for security, when the motor becomes crazy ...., and will close while driving )
18th Oct 2015 2:06pm |
I see, thanks, I have been removing bit's of mine to make it far simpler and more reliable, the plunger that locks the ignition and the arm that locks the gearstick, wanted to remove the steering lock as JLR did with the later ones so want to know if it will work without them in place...
18th Oct 2015 2:36pm |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
@Haylands
19th Oct 2015 1:59pm |
