Home > Technical (L322) > L322 Wont Start, Clicking noise from behind dash |
NeilC Member Since: 01 Sep 2015 Location: Newcastle Upon Tyne Posts: 14 |
Hi Guys, Got into the car last night and the Key wouldnt turn in ignition, bar about 3mm, interior lights work fine but no radio. no lihgts on dash either, Heard a clicking noise from behind the dash & that was all the car would give me
18th Oct 2015 5:27am |
Hi Martin,
18th Oct 2015 6:07am |
The steering lock comes on automatically when you take the key out. The battery can be on its way out and still test ok on just voltage but if you do a load test on it it may show the issues. Since the winter is coming I would suggest to replace the battery anyway if it is older and it is showing these issues just to have peace of mind.
18th Oct 2015 6:18am |
Thansk for that, Ill get the battery changed today and hopefully that will resolve the issue,
18th Oct 2015 6:27am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
The clicking you can hear behind the dash is the steering lock locking and unlocking, that is done by the chip in the key being recognised by the immobiliser... There is also a solenoid operated plunger that prevents the key from turning and it sounds as if this is the one that isn't working.
18th Oct 2015 8:37am |
Thanks for that Pete,
18th Oct 2015 8:53am |
Hi Guys,
18th Oct 2015 10:05am |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 |
Have you tried another key? might be the transponder in the key - alo try to fully charge the battery, it might have been sitting on the shelf at bit!!
18th Oct 2015 10:13am |
If you get a click behind the steering wheel then that is the transponder working, AFAIK (and the information is not definitive from all I have read) the problem could be the steering column lock, if it doesn't unlock fully then it won't let the car start, the way to check this is, when it goes click click and the key won't move, remove fuse 18 from the fuse box in the passenger footwell, leave it out for 30 seconds and then put it back in, make sure it goes in the right place as there are unused fuse slots... if it then works let me know and I'll type some more.... Pete
18th Oct 2015 10:19am |
Hi RP,
18th Oct 2015 10:20am |
Ill give fuse 18 a try too Pete and advise
18th Oct 2015 10:22am |
I had a problem with with a occasional non start. When turning the key there were a few 'beeps' from around the centre console and nothing else - . This turned out to be the ignition barrel (as mentioned byPete).
18th Oct 2015 10:31am |
Pete,
18th Oct 2015 10:49am |
No, that's the confirmation that it is what I thought it was... watch this space... a fare bit of typing coming... Pete
18th Oct 2015 10:57am |
