![]() | Home > Maintenance & Mods (L322) > V8 M62 without a rear exhaust box.... too darn loud |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
You'll probably find you'll only need to replace the standard back box with a couple of small silencers on each tail pipe to bring it down to a pretty reasonable level. Yeah they may still get bashed but there will be less there to bash than the massive standard one.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8379 ![]() ![]() ![]() |
That was my daughter, she's used to it..... Shandonman, well spotted, the yard of bricks... WD... was fed up with it 5mins after taking it off.... it's much louder in person than that clip, makes your ears bleed.... Zirconblue, depends on the silencers, the original is a massive job, two little boxes wouldn't do much at all, I've got all the bit's together now, to reduce the sound you need to reduce the size of pipe as well, the original tailpipes are smaller bore than the middle pipes... anyway if it's not quiet after this then it will have an original back on and a massive skid plate.... Pete I now have permission from the boss to use Y.O.L.O. Enjoy life __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
agreed the original is massive, but it does make the car basically silent.
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
Saw one the other day near home with 4 huge stainless pipes out the back,couldnt see a box,not as loud as this one but sounded great all the same and his pipes looked fantastic,not sure what he must have paid for them !! |
Right, being the tight git that I am I decided to do it with second hand parts, well, some of it, found a rear box from an Audi S4 that was smaller in every direction than the original one, best bit was it's less then 3 1/2 inches top to bottom and it's made of Stainless Steel...
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 ![]() ![]() ![]() |
And the ear drums won't bleed any more....... |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Pete, aren't you supposed to drift around the bends like the Bowler? |
It's pretty well tucked out the way, bit difficult to see from the photo but you have to get much further back before you can see it under the bumper, you can see half the rear subframe first, and my bumper is shallower than a standard one....
Need another few hundred BHP for that...!!! However my wifes 3.2 V6 Audi TT does awesome 4WD power slides.... ![]() ![]() I now have permission from the boss to use Y.O.L.O. Enjoy life __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 ![]() ![]() |
Get a couple of side exits on there |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
Nice work. Neighbours are happier. Howard
