![]() | Home > General > can you identify this noise |
I know, I'm thinking of starting a club! So far it only has one member lol! Someone see if you have the wiring there already, that will be the key... Either in the boot, right hand side behind the fuse panel or nsf wheel arch under the battery tray (accessible when wheel arch liner removed) It needs (minimum), 12V power, switch (to earth to tell it to run), fuel (supplied by a small fuel pump) and a relay to run the coolant pump The unit itself is pretty much self contained:
FBH by d86cfv, on Flickr ![]() |
iT LAD Member Since: 08 Jul 2010 Location: Surrey Posts: 1350 ![]() ![]() |
Scarey, I thinks it's the FBH mate... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35480 ![]() ![]() |
its official then rob.... |
