Home > Maintenance & Mods (L322) > Rear wheel arches FFRR 12 |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 350 |
Re: Rear wheel arch protection / inner arch
15th Oct 2015 8:49am |
Hi Peter
15th Oct 2015 9:21am |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 500 |
Hi,
15th Oct 2015 12:47pm |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 600 |
How many meter's you order ? thanks paul |
15th Oct 2015 6:46pm |
Hi Paul
15th Oct 2015 8:13pm |
Hi Peter Have a look at when the cars on the lowest suspension setting - there's not much clearance for you if you were under her !!!!! - I am sure they have a mind of their own Good luck with yours if you decide to do it - |
15th Oct 2015 8:18pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3067 |
These were fitted to the Freelander as standard and can be bought from Dan @ Duckworths. They're also fitted to our 2012 from the factory so should also be available.
15th Oct 2015 11:20pm |
I'm going to upgrade the rubber rear arch trims on our 2012. Theyre genuine LR/ arches are not affected by rust.
ndf's plastic strips don't seem to go out of shape like the original ones. Thanks |
28th Oct 2015 6:02pm |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
^--- +1 for @NiceDayForIt solution
28th Oct 2015 6:48pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7792 |
I’ve just ordered some of the plastic door edge ones. The Land Rover ones have all corroded and bent out of shape.....
6th Jul 2021 8:45pm |
