Home > General > WESTMINSTER L322
^ reminds me of the old John Cleese customer service videos he made after leaving Monty Python.
He played a repair guy who was asked to look at a faulty bit of kit, but after taking a look, came out with the immortal words, "ah, I see the problem, you've been using this haven't you?"
Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #352104 13th Oct 2015 7:17pm
CS
Laughing Laughing Spot on. Only Range Rovers since 1988
Post #352202 14th Oct 2015 10:34am
MachineHead
Scotland 2009 Range Rover Westminster TDV8 Mariana Black
I have an 09 WM and I think so far I must have been exceptionally lucky ...was 2012 a bad year for them?
Mine did get warranty repair for tiny bubbles appearing on the tailgate last year but other than that it has been pretty faultless. The sticky rear brakes I can agree with...mine have stuck slightly twice...but in my case it was really my own fault parked up and underused over 2 week periods...that said other cars I have or have had have not done this.
I had this exact same issue on the D3 and they look very much like the same rear calipers...it tends to happen when the pads are part worn more, as in half way through life and the caliper piston is sitting half out when uncompressed. I also found that the brake pads can cause the issue themselves I shaved a bit off the tabs using a grinder last time mine got sticky because on that instance the caliper piston did not seem stiff and it worked a dream. 09 TDV8 Westminster, Mariana Black, Rear seat entertainment, hatch bag and 2 slobbery mutts
Post #352334 15th Oct 2015 12:19am
^The rear pads stick be because the calliper/pad carriers rust slightly where the ears on the pads sit, making them tight and stick. To fix remove the carrier and clean with a file and re assemble, all will be fine and dandy.
It's not just the FF this affects it's any car with the TRW calipers, fixed the same problem on a mates NV200 van the other day. Pretty much the same caliper setup. There is nothing that can't be fixed with a hammer😜😜
Post #352337 15th Oct 2015 6:28am
