![]() | Home > General > can you identify this noise |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35480 ![]() ![]() |
started the RR this morning and for about 10 seconds i had a droning noise coming from the near side front of the engine/wheel area , RR was not in motion btw. ....any ideas ?..its happened once before after a coldish night. ... - .- -.
Could it possibly have been the viscous fan. They can be noisy when first starting up after a cold night |
Are you joking? With all the discussion on the FBH recently you really need to ask? |
forgive my naivety dan..so it makes this noise then... @47p2.. ![]() Y. O. L. O. . |
Forgiven. Yes it makes a Whoosh that kinda goes on for ages till it reaches full throttle/burn. Almost like a little jet engine. Should be most audible from the passenger side power vent. |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
I could never hear my FBH over the viscous fan noise. |
so is this a switchable thing cos i sure i havnt got any timers set ... - .- -.
If you don't pre-warm it should come on automatically to help the car get up to operating temp. Otherwise it takes ages. |
thanks richard...best i read the 'fbh' thread now. |
Yes, otherwise Dan will give you a hard time. |
indeed , i just didnt associate the noise with the fbh... |
my reputation precedes me ![]() ![]() |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
Can FBH's be retro-fitted or is it a massive ball ache? 2006 Mercedes CLS
Depends on the functionality you want. You could fit a webasto pre-heater fairly easily in the space where the original goes, use all the factory pipes etc but if the wiring is not there to talk to other systems you could then just use the default webasto setup which is a timer and/or remote. The Rover/MG's that dont have the TV screen just use a webasto timer in the cubby box, as well as having the T90 remote unit as an option. You can also use a GSM switch to activate it by phone/text ![]() ![]() ![]() |
