Home > Maintenance & Mods (L322) > Service items for 2007 TDv8 3.6
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Hi all. Had my FFRR for a month or so now and looking for some advice on keeping it in tip top condition. I have had gearbox oil and filter changed. It's had a full service and I'm getting diffs oil changed soon.
I've read about turbo hoses going so is this something I should change.
All advice greatfully received
Thank you 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #351819 12th Oct 2015 11:01am
dolph34
Anyone ? Just looking for parts that wear that I could keep an eye on Top hoses Etc Thanks in advance 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #351965 12th Oct 2015 10:48pm
Sounds like you have the right idea.
Diff oils,
transfer box oil
Gearbox oil and filter change
Engine oil service
Brake fluid change
Remove and check the top inter cooler hoses, they are relatively cheap so a swap would be good if they have never been check the coolant hoses round the expansion tank for chaffing esp the hose which comes off the bottom.
Redecorate rear silencer
Check rear arches for rust under the door shut seals
Check upper tailgate for rust under the lip
Condition the seats
Nothing much else really on the regular maintenance list, after these it is a replace as needed component list (I'm sure someone will add though)
Alternator
Brakes
Egr valves
Suspension components incl front drop links
Hope this helps There is nothing that can't be fixed with a hammer😜😜
Post #351971 13th Oct 2015 6:45am
As above + Coolant change... Thumbs Up
Post #351972 13th Oct 2015 6:51am
dolph34
That's greatl. Thanks NMJ and Craig. I plan on keeping her for a few years so this will reslly help. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #351974 13th Oct 2015 7:03am
Check for surface rust underneath as you live in Eire it may have lived near the coast? A wax oil treatment never goes a miss Thumbs Up
Post #351975 13th Oct 2015 7:05am
dolph34
Thanks Craig. I've had a body guy look at her and he only found a small blister on rear passenger arch. The work should be done in the next few weeks 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #352118 13th Oct 2015 8:15pm
Post #352130 13th Oct 2015 9:56pm
