![]() | Home > Technical (L322) > fuel gauge.. bit of a strange one? |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2587 ![]() ![]() ![]() |
Does the 'miles left' change at the same time? |
tone2711 Member Since: 29 Aug 2015 Location: staffordshire Posts: 32 ![]() ![]() ![]() |
hey thanks for reply no its stays at around 420 range remaining? i will look tomoz though again whilst driving work.. could that be an issue if range changes? what could it point too? remaining silent when one should be protesting makes cowards of brave men. |
thanks rosco for reply no stays around 420 range.. i will check tomoz though. what could it be any idea? tone remaining silent when one should be protesting makes cowards of brave men. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
the gauge is governed by the 2 in tank sender units, it basically takes an average of both of the units, and displays this as the reading. It could be that one of the senders is at fault and the gauge is having a dicky fit dos it doesn't understand the inputs its getting.
Sounds like one of the senders to me, common issue, as long as the miles left doesn't change it should be a sender, pain in the proverbial but sometimes sort themselves out, not much help I know |
M3DPO Member Since: 10 Oct 2015 Location: Nottingham Posts: 7 ![]() |
Coming from the D3 side I can only explain the characteristics of a D3 and add I have had experience of this "feature". The easiest way to explain it is imagine it is a clock(timepiece), when the fingers go past 12 the next figure is 1, this is what is happening with your gauge the needle is slightly out of sync with the sender and is going slightly past full, this in turn is taking it to the next figure which is zero. Taking it further I have seen the opposite situation when the fuel is very low or when the engine has been switched off the needle has rested at full. I am sure it will correct itself when you have used some fuel. |
thanks for info DPO... i have thought ive perhaps knocked something out of kilter filling to top.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I bet when you tell the missus' about the funny readings, and what to expect, all she will say, is....
