Home > Technical (L322) > L322 4.4 Geabox acting up |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
gearbox radiator?,
12th Oct 2015 11:58am |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
Hi PaulNorway.
12th Oct 2015 11:59am |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
what can also happen, (on mine, fixed by previous owner, ) was that the coolant lines can collapse internally on the rubber parts, and block them, enough for oil to not flow round. ie the gearbox radiator is not at fault. this was done after he changed the box, and rad. and hence, then the lines. i guess its possible to try to pass a test amount of fluid through a suspect line etc. the rubber beaks down, and swells internally, and blocks the route etc. |
12th Oct 2015 1:59pm |
