Home > Technical (L322) > L322 4.4 Geabox acting up
PaulNorway
Norway 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Hi I have a 2002 4.4 RR with apx 125.000 miles. gearbox has been flushed and filter/oil changed.
when driving for a while i experience engine revving up, hesitation and a hard clunk when using kick down.
If i go to manual and change gears manually it works perfectly.
If I go to a stand still (neutral) and put it back into drive it will hesitate and if i hit the throttle quickly it will clunk into gear and can even make a squeaky sound.
These problems only occur after 15/20 minutes of driving never when cold.
Have checked oil level witch seems Ok but mechanic thought "the oil was very warm".
ideas anyone_
Paul
Post #351820 12th Oct 2015 11:22am
gearbox radiator?,
http://www.fullfatrr.com/forum/topic25800....x+radiator ... - .- -.
Post #351822 12th Oct 2015 11:58am
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Hi PaulNorway.
Were the problems experienced before the fluid change? (Dexron3? LT1174?
What oil was put in the gearbox when changed?
Did the problems start not long after fluid change?
At what mileage was the fluid change done?
I am sure someone else will be along shortly but they might like to know about the above questions. Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #351823 12th Oct 2015 11:59am
johnboyairey
what can also happen, (on mine, fixed by previous owner, ) was that the coolant lines can collapse internally on the rubber parts, and block them, enough for oil to not flow round. ie the gearbox radiator is not at fault. this was done after he changed the box, and rad. and hence, then the lines. i guess its possible to try to pass a test amount of fluid through a suspect line etc. the rubber beaks down, and swells internally, and blocks the route etc.
Post #351850 12th Oct 2015 1:59pm
