Home > Maintenance & Mods (L322) > Brake upgrade |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8513 |
They should feel pretty good.
10th Oct 2015 8:13pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1753 |
Pad compound can make a huge difference
10th Oct 2015 8:27pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
What brakes are you running? Are they factory LR pads? As thats important sir |
10th Oct 2015 11:02pm |
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 |
I suspect there the original pads as the cars new to me
11th Oct 2015 8:59am |
Check the condition of the cv boots and all the gaiters round the ball joints. Mine had split and somehow deposited grease on the discs
11th Oct 2015 9:34am |
When was the brake fluid last changed? |
11th Oct 2015 1:55pm |
Cheers I'll check the boots just in case ,it's not on the service history so I wouldn't be surprised if it's the original fluid L322 2008 vogue
11th Oct 2015 5:18pm |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
They would need to have cracked into the brake fluid when this was done (assuming they changed the hoses!), so at least the fronts will have been bled. But I guess it's too much to expect them to have renewed the fluid first?! |
13th Oct 2015 7:35am |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 |
I had my recall done recently while the car was in for service. while thay will replace the front hoses, and bleed and top up the brake fluid, they won't change it as JLR will only pay for fluid to bleed after the hoses have been replaced.
13th Oct 2015 8:43am |
