Home > Maintenance & Mods (L322) > Brake upgrade
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
Brake upgrade
I have the brembo brakes on my tdv8 but when I brake it feels so underpowered ,the hose recall was done a few months ago but it still feels vague and like it's not going to stop ,it could just be I'm used to cars that stand on there nose when you need them too .
Has anyone upgraded the discs and pads on theirs L322 2008 vogue
R53 Cooper S Works tuned beyond the works SOLD
R33 Nissan Skyline in rebuild 400bhp atw
Post #351602 10th Oct 2015 7:45pm
They should feel pretty good.
Don't forget that they are stopping the best part of 3 tonnes which is probably double what 4 pot brembos are usually asked to stop!
On my 3.6, the calipers were starting to show signs of age and the discs and pads were contaminated with something, swapped the lot and it was a massive difference. There is nothing that can't be fixed with a hammer😜😜
Post #351607 10th Oct 2015 8:13pm
Mikey
Pad compound can make a huge difference
Cheap pads give poor pedal feel, and fade much earlier
Stick with OEM pads, or uprated EBC items Thumbs Up
Post #351610 10th Oct 2015 8:27pm
Re: Brake upgrade
What brakes are you running? Are they factory LR pads? As thats important sir Thumbs Up
Post #351627 10th Oct 2015 11:02pm
Ivor
I suspect there the original pads as the cars new to me
Just checked they are landrover pads changed last year L322 2008 vogue
Post #351641 11th Oct 2015 8:59am
Check the condition of the cv boots and all the gaiters round the ball joints. Mine had split and somehow deposited grease on the discs Shocked
Not sure how it happened but reduced braking considerably. There is nothing that can't be fixed with a hammer😜😜
Post #351643 11th Oct 2015 9:34am
When was the brake fluid last changed?
Post #351689 11th Oct 2015 1:55pm
Ivor
Cheers I'll check the boots just in case ,it's not on the service history so I wouldn't be surprised if it's the original fluid L322 2008 vogue
Post #351710 11th Oct 2015 5:18pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Re: Brake upgrade
They would need to have cracked into the brake fluid when this was done (assuming they changed the hoses!), so at least the fronts will have been bled. But I guess it's too much to expect them to have renewed the fluid first?!
Post #351978 13th Oct 2015 7:35am
Full Fat Ray
Wales 2006 Range Rover Vogue 4.4 V8 Bonatti Grey
I had my recall done recently while the car was in for service. while thay will replace the front hoses, and bleed and top up the brake fluid, they won't change it as JLR will only pay for fluid to bleed after the hoses have been replaced.
I change my brake fluid religiously every 2 years - makes a massive difference to the life of the seals in the braking system. Easy job to do with a Gunsons 'easibleed' kit. Thumbs Up 2006 (56 Reg) 4.4 V8 Vogue In Bonatti Grey (Gorgeous!!)
Post #351987 13th Oct 2015 8:43am
