![]() | Home > Maintenance & Mods (L322) > Removing rear door card. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35465 ![]() ![]() |
any good David,
I found that video stan but it just seems to gloss over the centre clip, or else he broke it off in his first attempt to remove the door card and never bothered refitting it.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 ![]() ![]() |
Here was my experience:
Craid will know , he's for ever taking his FF apart.. ... - .- -.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
Lift the door card up and it will leave the clip on the door, remove the clip and refit to door card before refitting door card sir |
All done |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
As NDFI and Craig say, have to lift card up once bottom and side clips released. I found that a good tug upwards on the forward edge of the card does the trick. I am waiting for the fella from National Windscreens to come and replace the glass which got shattered yesterday. (happened whilst car parked up outside my mums, 90% sure it was caused by a stone thrown up by a neighbour"s lawnmower. The bloke didn't know and it couldn't be proven anyway). It's a sod to clear up the pieces of glass inside the door! Previous cars:
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1538 ![]() ![]() |
I just had to remove the right rear door card to remove/replace a faulty lock.
Discofish Member Since: 21 Jul 2020 Location: Nottingham Posts: 105 ![]() ![]() ![]() |
Hot glue was going to be my suggestion, super glue is not flexible once cured so likely to come off again |
stuart_2006 Member Since: 17 Jul 2018 Location: Holsworthy, Devon Posts: 126 ![]() ![]() ![]() |
Loctite do a flexible super glue now. Google Loctite 480. I've used it for a few things and it seems to do the job. |
I like the idea of hot glue but have no idea of which one. I suppose i could try what I hae but will it last for years.
I never updated this. I had to do the front left door as well when its lock failed earlier this year.
I had to remove the LH rear door card because I;ve had another door lock failure.
I spoke too soon. |
