Home > Maintenance & Mods (L322) > Removing rear door card.
I want to remove the rear door cards.
Can anyone tell me how you "Ensure the Centre Trim clip is released" as per Rave.
I have the card released all round the edges, just don't want to break anything releasing the centre clip which looking at it I'm not quite sure how it releases.
Thanks.
Post #351660 11th Oct 2015 10:36am
any good David,
Post #351665 11th Oct 2015 11:48am
I found that video stan but it just seems to gloss over the centre clip, or else he broke it off in his first attempt to remove the door card and never bothered refitting it.
I've got all the edges of the card loose easily enough but just can't see how to undo the centre clip.
No doubt once I get off and see what's what it will be easy in the future.
I just don't want to force anything in the meantime.
Post #351671 11th Oct 2015 12:07pm
Here was my experience:
http://www.fullfatrr.com/forum/post143664.html#143664
Just have to tug away and hope for the best, same as with many panels that need to come off! .
Post #351679 11th Oct 2015 1:20pm
Craid will know , he's for ever taking his FF apart.. ... - .- -.
Post #351680 11th Oct 2015 1:21pm
Lift the door card up and it will leave the clip on the door, remove the clip and refit to door card before refitting door card sir Thumbs Up
Post #351686 11th Oct 2015 1:45pm
All done Thumbs Up
Metal tongue on the door card that goes into a fragile looking black plastic clip mounted on the door framework.
Must be the usual problem of never been apart before and as such needed a bl Censored dy good pull.
Frightening when you think of the possible damage you could cause to the very expensive door card.
Post #351693 11th Oct 2015 2:41pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
As NDFI and Craig say, have to lift card up once bottom and side clips released. I found that a good tug upwards on the forward edge of the card does the trick. I am waiting for the fella from National Windscreens to come and replace the glass which got shattered yesterday. (happened whilst car parked up outside my mums, 90% sure it was caused by a stone thrown up by a neighbour"s lawnmower. The bloke didn't know and it couldn't be proven anyway). It's a sod to clear up the pieces of glass inside the door! Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #563774 6th Aug 2020 12:11pm
p38arover
Australia
I just had to remove the right rear door card to remove/replace a faulty lock.
The problem no is that of the 11 retaining clip supports that are glued onto the card, 9 have come off. The glue has failed, probably from 17 years of Australian heat.
Are there any suggestions for a suitable adhesive to glue them back on? I am considering superglue. It looks like they were originally stuck on with hot glue.
 Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #569214 8th Oct 2020 1:09pm
Discofish
England 2003 Range Rover HSE Td6 Oslo Blue
Hot glue was going to be my suggestion, super glue is not flexible once cured so likely to come off again
Post #569227 8th Oct 2020 3:38pm
stuart_2006
Loctite do a flexible super glue now. Google Loctite 480. I've used it for a few things and it seems to do the job.
Post #569246 8th Oct 2020 7:39pm
p38arover
Australia
I like the idea of hot glue but have no idea of which one. I suppose i could try what I hae but will it last for years.
Thanks for the info on Loctite 480. I'll check it out. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #569295 9th Oct 2020 12:41pm
p38arover
Australia
I never updated this. I had to do the front left door as well when its lock failed earlier this year.
I used Sikaflex 227 - sticks like the proverbial to a blanket Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #635179 22nd Jun 2022 12:22pm
p38arover
Australia
I had to remove the LH rear door card because I;ve had another door lock failure.
This time, the door card came apart at the centre join and another clip (of the 11) came off, too.
I pondered how to rejoin the top and bottom halves of the door card. I thought about Sikaflex but that would take too long to cure.
I then considered and tried hot glue (using the cheap hot glue guns that I already owned) but it would set before I coould assemble the cards.
I was looking at the local hardware store (Bunnings for Aussie/NZeders) and saw a DeWalt hot glue gun with a much more powerful heater, 95 watts - DEWALT DWHT70419-3 Rapid Heat Ceramic Glue Gun.
Not only that, it came with 3 different nozzles, one of which has a larger bore and is much longer. Not cheap (A$47) but then...
I bought some dual heat glue sticks to go with it. They were from Stanley.
I jigged the two sections up on wooden blocks and put hot glue at each end of the join. Then, after the glue had set up, I worked my way along the joint about 100mm/4" at a time sliding the long nozzle under the seam and squirting in a lot of glue. After each 100mm section had set up, I moved backward and forward form each end to meet in the middle.
Seems to have worked quite well. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #664460 19th May 2023 4:25am
p38arover
Australia
I spoke too soon. Sad
In the hot summer temps here in my garage (+50 deg C), the glue failed and the door card top and bottom separated. Pix to come.
I'll have to think of something else. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #681611 1st Jan 2024 6:52am
