Home > Technical (L322) > 2009 3.6 TD8 engine management fault |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7925 |
I'd find a dealer to read the codes - and drive there slowly
10th Oct 2015 4:07pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
Yet again money on passenger side turbo hose
10th Oct 2015 4:42pm |
I would agree if under hard acceleration & black smoke from the exhaust.
10th Oct 2015 4:50pm |
That's how mine went in France, little bit of smoke, but mostly bong/system fault and limp home, didn't really notice the smoke until after the bong. There is nothing that can't be fixed with a hammer😜😜
10th Oct 2015 4:57pm |
dogsbody21g Member Since: 20 Aug 2014 Location: Devon Posts: 10 |
Thanks for the help. Located extensive split out of sight on upper offside intercooler hose. When everything opens up in the morning will see what I can locate locally to 'lash-up' and get back on the road then a visit to the dealer in Foggia! |
11th Oct 2015 5:04pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
What is it with all this contaminated European air thats melting our hoses!! |
11th Oct 2015 5:36pm |
at least you have found the culprit.
11th Oct 2015 7:05pm |
And replace both hoses when you do it - if one has gone, the other is not usually far behind |
11th Oct 2015 7:50pm |
Lashed together with tape and whipped with strong and no problem reaching dealer 40 miles away in Foggia. unfortunately no replacement part but a back street garage nearby cut out split section and splinted with a section of exhaust pipe bent and shaped + X2 additional jubilee clips - X 2 chaps about to have their lunch dropped that for 40 minutes to sort there and then and then tried to refuse any payment.! Another 300 miles later all absolutely fine and not now anticipating replacement until back in UK. |
12th Oct 2015 8:10pm |
Take it gently and you should be ok There is nothing that can't be fixed with a hammer😜😜
12th Oct 2015 8:49pm |
Good news.
12th Oct 2015 9:39pm |
12th Oct 2015 9:41pm |
