Home > Technical (L322) > Air Bag Warning Light
RR1234
2014 Range Rover Autobiography SDV8 Luxor
The warning light has just come on with regard to the airbags on my 2003 RR Vogue. I reckon this is a preset warning as it falls within the 12-15yrs old bracket. Any advice on how to get the airbags checked and the light reset without costing a small fortune? Thank you
Post #349789 28th Sep 2015 3:26pm
moved to the appropriate section.. ... - .- -.
Post #349794 28th Sep 2015 3:30pm
johnboyairey
i would find someone with a diagnostic hand held, like the typical rsw allcomms or iidtool etc, and get a code from it, this will tell you the item that requires checking. it totally possible any unit may have failed, or been disrupted etc. but the first item to check, (i have same car) is the battery terminal blow-off yellow connector. easily knocked about when dealing with battery connections. can also be the airbag ecu.. sometimes not re-settable, and needs changing with a secondhand one. any memebers in your area? with diagnostic? -otherwise, you are going to fail your (english) mot test. not so sure in Ireland...
when item is sending good signal, you can then reset airbag ecu, and all is well again.
Post #349796 28th Sep 2015 3:41pm
RR1234
This is really helpfull and very much appreciated. MOT is not due nor is the next service until February. I'll update fullfatrr when I get it sorted - most likely in the next few weeks. Thank you
Post #349899 29th Sep 2015 9:31am
Yep, as John says... could also be the plugs under the front seats, they can get disturbed by stuff under the seats (just had to sort SWMBO TT today, a stray ice scraper had knocked the plug enough to put the light on) All airbag plugs are in yellow so they are easy to find and check but as John says for most faults you need to have the system reset after fixing the fault or the light stays on....
There is no inbuilt age related warning system... they recommend changing them after 10 years but that would probably cost you more than the FF is worth... it's got a few... Rolling Eyes Pete
Post #349991 29th Sep 2015 8:10pm
RR1234
Thanks Pete - sorry for the delay in acknowledging your feedback I've been off line for a bit
Post #351431 9th Oct 2015 8:04pm
Thumbs Up Thumbs Up Pete
Post #351441 9th Oct 2015 9:07pm
As above but could easily be the steering column clock ring... Do more & more of these as the cars get older Rolling Eyes
All guesswork until you get the codes read Whistle Let us know when you have sir Bow down We’ll see what other advice we can offer at that point Thumbs Up Thumbs Up Thumbs Up
Post #351455 9th Oct 2015 11:40pm
RR1234
Thanks guys
Post #351500 10th Oct 2015 11:46am
holidaychicken
I had a random airbag light that all comms read as 'Battery disconnect unit' which is the red plunger that fires of to disconnect the battery after a heavy crash as did a friend of mine.
Both appeared for no real reason, same fault and allcomms cleared it and has never been back but as already pointed out, until you have diagnostics it could be anything
Post #352308 14th Oct 2015 10:23pm
RR1234
Thank you. I haven't had a minute to get to my mechanic to check it but will feedback when I do.
Cheers
Post #352604 16th Oct 2015 7:02pm
