Home > Technical (L322) > Air Bag Warning Light |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35377 |
moved to the appropriate section.. ... - .- -.
28th Sep 2015 2:30pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
i would find someone with a diagnostic hand held, like the typical rsw allcomms or iidtool etc, and get a code from it, this will tell you the item that requires checking. it totally possible any unit may have failed, or been disrupted etc. but the first item to check, (i have same car) is the battery terminal blow-off yellow connector. easily knocked about when dealing with battery connections. can also be the airbag ecu.. sometimes not re-settable, and needs changing with a secondhand one. any memebers in your area? with diagnostic? -otherwise, you are going to fail your (english) mot test. not so sure in Ireland...
28th Sep 2015 2:41pm |
RR1234 Member Since: 29 Apr 2013 Location: Northern Ireland Posts: 55 |
This is really helpfull and very much appreciated. MOT is not due nor is the next service until February. I'll update fullfatrr when I get it sorted - most likely in the next few weeks. Thank you |
29th Sep 2015 8:31am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8275 |
Yep, as John says... could also be the plugs under the front seats, they can get disturbed by stuff under the seats (just had to sort SWMBO TT today, a stray ice scraper had knocked the plug enough to put the light on) All airbag plugs are in yellow so they are easy to find and check but as John says for most faults you need to have the system reset after fixing the fault or the light stays on....
29th Sep 2015 7:10pm |
Thanks Pete - sorry for the delay in acknowledging your feedback I've been off line for a bit |
9th Oct 2015 7:04pm |
Pete
9th Oct 2015 8:07pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
As above but could easily be the steering column clock ring... Do more & more of these as the cars get older
9th Oct 2015 10:40pm |
Thanks guys |
10th Oct 2015 10:46am |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
I had a random airbag light that all comms read as 'Battery disconnect unit' which is the red plunger that fires of to disconnect the battery after a heavy crash as did a friend of mine.
14th Oct 2015 9:23pm |
Thank you. I haven't had a minute to get to my mechanic to check it but will feedback when I do.
16th Oct 2015 6:02pm |
