Home > Maintenance & Mods (L322) > V8 viscous fan removal tool |
jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259 |
hi mate, i thought britpart parts had a standard 2 year wotsit?
2nd Jul 2015 5:51pm |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 790 |
The one I was replacing wasn't a Britpart one, the new one is. |
2nd Jul 2015 9:41pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
im not familiar with this engine, however, the same proccedure to many similar engines, would be, to draw a diagram first, and take a few pics, of how the belt is threaded etc. as it can be very confusing when the belt is off, as to how it goes back on! its usyally a case of flexing a small damper that applies spring tension, (an idler pulley) and pulling it off there, then releasing the tension. then belt is removed, then threaded back on, and a spanner is used to re-spring the tensioner, to allow it back on, and released, confirming, that the grooved belt is indeed on the same groove on all pulleys. normally, you can start car up to check its running right, and inspect, with torch, with the fan off, for a minute of two.
8th Oct 2015 8:35am |
