Home > Technical (L322) > Knock control offset fault - 0x1D7 P0000
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Hi
So I got rid of mis-fire on the V8 - engine is very smooth
But then coil pack 5 failed and I got a misfire due to that.
Cruised home about 4 miles and found the rubber sleeve over spark plug had a small rip in it and white powder where it the spark probably arced through to the side of the well where the spark plug sits.
Replaced the coil pack - engine all well and smooth but AllComms fault code shows
0x1D7 P0000 Knock control offset fault.
Anyone any ideas - I guess it is not the actual sensor - perhaps some connector or wiring disturbed or an ECU (which may generate an offset freq or voltage - just guessing not really know what I am talking about) on its way out?
I tried clearing the fault via AllComms - but it persists - even without the engine being turned on and off again after clearing.
Thank you for reading Smile Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #350912 6th Oct 2015 5:22pm
have you cleared the fault and done a battery reset? ... - .- -.
Post #350914 6th Oct 2015 5:24pm
SMUTT
Hi Stan
Thank you very much for that.
I read about battery reset (can'rt find definitive guide) - my interpretation was it was everything just short of actually removing the battery in the wiki. I also (with some caution and eyes closed - the fact that it has an explosive charge scares me whenever I am near it) briefly shorted the positive cable terminal (disconnected from battery) to earth.
OK so fault code gone - thank you Stan for the tip.
Will take for a drive later and recheck codes. Howard
Post #350976 7th Oct 2015 10:29am
SMUTT
Knock Control fault stayed off - just done 150mile journey to coast and back - engine smoother than ever - a ture pleasure to drive.
Thanks for your input Stan Bow down Bow down - certainly a better outcome than I was thinking (sensor replacement or even ... to dealers for endless changing of parts while they guessed which one was faulty at my expense) Howard
Post #351573 10th Oct 2015 6:21pm
'most' FF glitches tend to be addressed by a battery reset or replacement battery..
glad yours is ok.. ... - .- -.
Post #351579 10th Oct 2015 6:47pm
