Home > Technical (L322) > brake warning light
33sport
2007 Range Rover Vogue TDV8 Stornoway Grey
brake warning light
hi my ff vogue tdv8 every now and then shows the warning "Check Brake Pads", this does not happen all the time and can go for days with no warning. ?
I have had the pads checked, rear ones renewed, just had the recall done and local dealer gave her a clean bill of health check.
Post #350440 3rd Oct 2015 10:35am
Replace sensor wires?
Post #350442 3rd Oct 2015 10:38am
^ +1
i suspect the sensor wire has been damaged whilst the hoses were done.. ... - .- -.
Post #350444 3rd Oct 2015 10:42am
miggit
Or some contact cleaner on/in the brake ware sensor plug, the sensor is either on or off, and once it has been turned on there is no way to turn it off without replacement. so if yours is going on and off it must be either a broken wire or a bad connection in the plug Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #350467 3rd Oct 2015 11:56am
