Home > In Car Electronics (L322) > 2005 Range Rover vogue TV not picking up channels ...help pl
Stewince79
United Kingdom 2004 Range Rover Vogue TDV8 Java Black
Hi I have a 2005 54 plate vogue and my TV does not pick up channels and my venture cam does not work too it's charged up glows green and then if u press the buttons on the screen it puts the lights on the cam so it's connecting but no picture
Please help
Post #349683 27th Sep 2015 8:04pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Not sure about the venture cam, but unless you have had the upgraded digital tv module installed you won't pick up the channels.
Post #349686 27th Sep 2015 8:19pm
Stewince79
Well I thought that but then I bought a lot of ebay that was for my model that should have converted it but then it came and it didt fit after contacting the seller he then produced pictures of the modual in his car and mine was different he said mine was the digital one
I'm confused but here's some pics of my modual
mod edit, pic of unit..
Post #349687 27th Sep 2015 8:37pm
PaulB
There are a lot of rest of the world tv modules doing the rounds on ebay that won't work in UK cars.
Do a search on here and find the correct serial number and then check it against yours.
BTW You can't have a 2004 TDV8 it must be a TD6
Post #349689 27th Sep 2015 8:51pm
Stewince79
All I know it's a diesel and 2005 but on 54 plate lol I'm crap with cars
Post #349691 27th Sep 2015 8:59pm
PaulB
Thumbs Up Its a TD6.
http://www.fullfatrr.com/forum/topic10119....digital+tv
Post #349692 27th Sep 2015 9:05pm
A 54 plate will have an analogue TV tuner , the newer hybrid tuner is in fact slightly slimmer and I think your Venture Cam has a gubbed batterie . When they start to die the led's work but there isn't enough juice to transmit . 2008 MY Supercharged
Post #349725 28th Sep 2015 2:33am
Its the swap over year so a picture of your unit would help....
Post #349728 28th Sep 2015 7:22am
pic in post now... Thumbs Up ... - .- -.
Post #349734 28th Sep 2015 8:40am
Weegie
If it doesn't have the spare green port then analogue? Just seen the pic - analogue IMO. John
GAP iiD BT-Sold
Post #349759 28th Sep 2015 11:31am
Zirconblue
axle wrote:
A 54 plate will have an analogue TV tuner , the newer hybrid tuner is in fact slightly slimmer .
Is it? When i replaced mine the Hybrid unit is physically identical to the old analogue one.
Looking at the pic posted above, that's an analogue one. Which is what mine had when i got it, the hybrid looks exactly the same but the label has the word "Hybrid" on it. It's a straight swap, but i found i had to use the IID tool to tell the car i'd fitted a digital/hybrid one to get it to display the channel names correctly. I also later used the IID to tell the car it was digital only, it makes it ignore the analogue band and find channels faster.
There are basically 3 physical types of TV tuner fitted to the L322, The BMW one (non touch screen), the MOST one (touch screen) and the later Digital unit (2009 onwards).
Post #349812 28th Sep 2015 5:10pm
When I changed the tuner on my last one the Hybrid was definitely thinner because for a while I just slid it down next to the old analogue box and plugged it in and there wasn't nearly enough room for a same sized box . I then installed it properly later and it also had different spaced mounting holes , but It did say Jaguar on it and came from Wiggs . I assumed they were all the same but It's just as possible that there are a few choices that work . 2008 MY Supercharged
Post #349885 29th Sep 2015 3:49am
Zirconblue
Yeah mine was just identical to the original, there was no way it would fit in there without removing the old one. (it's a complete pig of a job to remove the old one, for what looks like a simple task.
Presumably yours was sourced from a Jaguar XJ or something.
Post #349927 29th Sep 2015 1:59pm
n1cktdv8
My 2007 runs an analogue TV and tbh.....I can't think of a worse combination of TV+Car !!
In terms of the venture cam, mine was a nightmare to set up but I got it running and use it with the sucker on the rear of the tintent for reversing Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #349936 29th Sep 2015 2:46pm
