![]() | Home > Technical (L322) > Something strange is happening! |
goncalo Member Since: 26 Apr 2013 Location: Portugal Posts: 170 ![]() ![]() ![]() |
Hello,
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 ![]() ![]() |
If it's your gearbox then you will really feel it between 30 and 50 mph (50 to 80 Kmh) and it will go instantly you knock the gear lever into sport mode / manual.
birchyman71 Member Since: 18 Feb 2013 Location: stockton on tees Posts: 147 ![]() ![]() ![]() |
My td6 did this slowly it got worse and it turned out to be the no 1 injector. |
You lucky lucky |
miggit and birchyman71,
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6414 ![]() ![]() |
What is the car like starting from cold, how many turns of engine before it fires. Has this changed - i.e. takes a little bit longer to start. This would evidence an injector problem.
I got my injectors cleaned and tested by a Bosch Diesel Agent, this was the point that 2 were found to be not working at all well. But they were able to recondition them for me and it cost £130 per injector. This was a lot cheaper than buying new ones, and I had the piece of mind that they were all working correctly.
Joe90, or should I say Tim |
goncalo, from my calculations your car has done 84,000 km's or 51,000 miles this is an OK distance, but change the oil and filter now. You might get away with just changing the oil in the sump of the gearbox and the filter, it depends on how dirty it is. If it is a lot darker than the new oil I would power flush the gearbox. What ever you do, do not wait until L/R say the oil has to be changed, as this is too late and the box will be damaged. Yesterday I couldn't spell Engineer... Today I are one!
Thanks miggit!
Oh miggit! I remember now the owner of the garage i go the LR specialists, one of the owner many years ago worked worked on BOSCH injectors cleaning department! I will go talk with him! |
Good Luck Buddy |
Thanks miggit!
