![]() | Home > Maintenance & Mods (L322) > SCREECH |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
I've done a search and not much comes up in relation to this so here goes.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
the disc cover bent? ... - .- -.
Disc covers are fine |
i had a stone caught in between the disc and cover and the only way to get it out was to reverse a few times but that doesnt explain why yours happens on full lock.... ... - .- -.
Car is stationary ?? |
steering pump maybe..just guessing now.. ... - .- -.
^ Yes I would also suspect the steering pump |
Surely it would screech on both locks if it were the pump? |
not sure how the pump works but it could be that on the right lock theres more strain on it.. ... - .- -.
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 ![]() ![]() ![]() |
Might be low on fluid , worth a check if you haven't already.
Worth checking the fluid level & the belt condition sir |
Fluid is fine (first thing I checked) and belt is less than 5000 miles?
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8376 ![]() ![]() ![]() |
If the tracking has been reset in the past then the central position of the rack may have changed, hence full right lock maybe further than full left lock.. then it screeches... they usually last for ages in that state, just don't hold it there, back off the lock a bit... Pete
