Home > Technical (L322) > FUEL TANK OVERFLOW SYSTEM |
Ziggy Member Since: 26 Dec 2011 Location: West midlands UK /sydney AU Posts: 265 |
Jesus Kent has changed a bit sense I was last there
23rd Sep 2015 1:01pm |
6029 king Stephen Member Since: 11 Apr 2015 Location: Sittingbourne, Kent Posts: 101 |
Thanks for the prompt - I have changed my profile to reflect my true location! Cameroon is not included in the list of countries on the drop down, hence why I have retained my country as UK but location as somewhere in Africa.
23rd Sep 2015 1:32pm |
schan51 Member Since: 10 Jun 2015 Location: Essex Posts: 8 |
I had the same issue when I brought the 2008 TDV8 a few months ago. I normally fill up the tank and when it clicks, I would pull the petrol pump hose out slightly and round it off to the nearest pound, which I had done on all previous car without issue. I did this on the TDV8 and when I went to pay for it, the lady told me there was leakage from underneath the car but being a diesel it was safe to drive off.
23rd Sep 2015 2:32pm |
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 |
In the Wiki you might like to check out the rave manual which has good illustrations and diagrams of the entire fuel system. This might give you a clue of what is above the point of leakage and potential source of problem. If you can't sleep at night then reading it will help you unless like me you like reading this sort of thing.
23rd Sep 2015 2:40pm |
Birdbrain Member Since: 19 Nov 2014 Location: Cheshire Posts: 74 |
I had this problem with my 2008 V8 diesel Vogue SE. Its a fairly common problem (apparently). The full tank breather that runs from the tank to the filler cap neck gets crushed by the body work / chassis and leaks fuel out all over the place when you tank it right up. Luckily mine was done under warranty as it entailed removing exhausts and dropping fuel tank to fix. Main dealer recommended wrapping pipe insulation around the plastic breather pipe to stop it happening again. I flooded Sainsburys forecourt twice in a fortnight! |
23rd Sep 2015 3:21pm |
heppsen Member Since: 14 Feb 2012 Location: germany Posts: 170 |
Sounds like breather line to me.
24th Sep 2015 4:32am |
I have never noticed this before but then in most of Europe you self-serve the fuel so you can stop filling on the second full click off. Over here all fuel is pumped by an attendant and some will fill up more than others. I had to stop one guy as he was trying to get in the last drop and I noticed that fuel was spill in on the floor. This most recent time the gauge is showing very much fuller than full, so I expect the excess has to go somewhere and until the gauge goes under the full mark, I will avoid parking on ground which leans down to the right.
24th Sep 2015 10:37am |
MikeB. Member Since: 04 Feb 2018 Location: 29320 Posts: 3 |
I have exactly the same problem like birdbrain.
22nd Apr 2020 3:54pm |
