Home > Technical (L322) > ff gave me a heart stopping time
saucyboar5
United Kingdom 2007 Range Rover Vogue TDV8 Zambezi Silver
Happy driving at 60...then all hell breaks loose..bong bong bong...engine malfunction...limited gears...suspension drops on its arse and there is no lights on the suspension panel..no throttle slowing down..ohhhhh s#it..stop turn it off start up again all mint...set off again. .then bong bong bong...arrrgghhh 3 times in a 10 mile run..
Big Cry Big Cry Big Cry
Having had a route about on ffrr has anyonegot a definitive answer to this problem...
Post #348709 20th Sep 2015 8:47pm
fill in your car profile so we know what you have..it helps with advice..... ... - .- -.
Post #348710 20th Sep 2015 8:54pm
Blade74
Australia
Make sure you're battery is in top condition.
How old is the battery?
Post #348722 20th Sep 2015 10:43pm
Nothing quite like the smell of Censored when the dreaded 'bong' goes off whilst driving along, I hated the outside temperature sensor in the winter time Big Cry
Post #348725 20th Sep 2015 11:16pm
johnboyairey
-yep... and the 'range less than 50 miles'... fuel 'bong'
she says...'oh! what now!'
they should have a 'bong' for 'danger', and mobile text type 'ping' for 'aware' moments
Post #348727 20th Sep 2015 11:43pm
Never saw the yellow light on in my 5 years of owning a FFRR, when I bought the car the yellow light was on during the test drive and showing 25 miles to go before running out and ever since then it was filled up when the gauge reached 1/4 tank. My wife has a knack of handing me the keys of her car when the yellow light is on Big Cry
Post #348728 20th Sep 2015 11:59pm
saucyboar5
on my profile the details are filled in Stan. ..but don't show when I click the profile bar on my post?
It's a 2007 vogue 3.6 tdv8
Cheers
Post #348730 21st Sep 2015 3:21am
ebajema
The behaviour sounds like voltage issues which would lead me to think, alternator on its way out. There have been quite a few alternators dying on forum cars if I remember correctly so have a look at the voltage with running engine etc. Check battery voltage and age as well of course and check for connections being loose would be my first guess. MY 2010 5.0 SC Galway green and sand interior!!
Post #348738 21st Sep 2015 7:14am
Sql
Poland 2007 Range Rover Vogue TDV8 Buckingham Blue
Yup, this always scares me when I hear the fuel range bong that sounds as if it was warning me that the car was about to autodestruct in 3... 2... 1...
Post #348740 21st Sep 2015 7:22am
proser
saucyboar5 - if you are near to Stafford then I have the IID Tool and should be able to read any fault codes for you, if needed Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #348744 21st Sep 2015 7:49am
Lost for Words
Cheers
Have you got the colour filled in? Wink Visiting from DISCO3.CO.UK
Discovery 3 TDV6 Auto HSE Zambezi Silver
Post #348745 21st Sep 2015 8:13am
Martin
Site Admin
You need to pick the colour to get the icon to appear Thumbs Up
Post #348751 21st Sep 2015 9:22am
saucyboar5
I'm only in Stoke. .
Post #348774 21st Sep 2015 1:57pm
saucyboar5
it won't let me pick one. .. Neutral Neutral Neutral
Post #348775 21st Sep 2015 2:03pm
Eirik34
Norway
I think you need to start over again - select Model (wait for the form to refresh), then Year, then.... etc. Happened to me as well when I tried to change to the correct color.
Post #348776 21st Sep 2015 2:11pm
