![]() | Home > Technical (L322) > TDV8 8spd gearbox slam? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
I think that folks were noticing this a few years back, can't remember the outcome though Ryan, mine does something similar, I only noticed it on the trip to France as a slight hesitation, as though the power has been cut for a split second. Before al resuming business as usual.
Yes Mark that describes it well. I knew the older 6 speed auto (eg on the SC) ones had so called gearbox slam, maybe when in slow moving traffic and that there was a software updated for that but didn't know about this seemingly minor glitch |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 ![]() ![]() ![]() |
+1 me to. more so at slow speed. does not happen that often, say once every 1k miles but coasting to say a traffic island in drive down to perhaps 10mph then decide it is ok to continue so press the pedal and there is definitely a second of no power before a bit of a jolt through what appears to be the drive train then all is well again. 405 AB exec seats Baltic and Cirrus
http://www.fullfatrr.com/forum/topic10797....8+motorway
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
The bump fix software on the 6-speed still doesn't resolve it fully. A transfer box clutch calibration helps, but it comes back again shortly... |
Would be handy to know what the TSB number is for the issue. According to the thread above Farnell in Leeds were referred to a TSB by Land Rover, and they recommended a specific download to fix it. So it is a know problem. There is nothing that can't be fixed with a hammer😜😜
Here you go;
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 186 ![]() ![]() ![]() |
Mine did it twice last month (coughed and felt like it was going to stall before regaining power) and I found the above post referring to the fuel injector software update on the forum. I passed this onto the dealer who updated the software and so far the problem has not recurred. |
