Home > Technical (L322) > FBH |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
Great feature....but it takes a fair whack out of the battery GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
19th Sep 2015 7:33pm |
ije44 Member Since: 01 Sep 2015 Location: Leicester Posts: 129 |
Paul,
19th Sep 2015 8:22pm |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 424 |
I don't know if the RR is the same but the X5 Webasto version had a sensor that would not allow the FBH to work if the battery charge was too low. It would always leave enough battery charge to start the car. 2017 5.0 Autobiography Supercharged
20th Sep 2015 5:48am |
Worst case is that you have to install a charger and plug it in at night MY 2010 5.0 SC Galway green and sand interior!!
20th Sep 2015 6:22am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8524 |
at least it worked when you turned it on!
20th Sep 2015 9:50am |
Brian Member Since: 06 Dec 2014 Location: Northern Ireland Posts: 138 |
So, on this subject I have a TD6 Vogue but no remote is there an easy way to check that all I need to do is buy a remote from ebay and try it or is there a world of expensive bits waiting for me? |
20th Sep 2015 11:38am |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
http://www.fullfatrr.com/gallery/albums/us...G_3703.JPG
20th Sep 2015 1:03pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3236 |
Brian, FBH was fitted as standard on the TD6. You are most likely to be missing the remote. John
20th Sep 2015 1:15pm |
mike whiskey Member Since: 11 May 2015 Location: Huntingdon Posts: 114 |
You won't necessarily have the receiver, and your heater won't necessarily be enabledto use as a parking heater.
20th Sep 2015 3:53pm |
I'll nip out and have a look now but problem no2 is that I have no front screen - the previous owner "upgraded" to a Kenwood all singing and dancing head unit |
21st Sep 2015 10:12am |
Had a look see and don't see the module - I have a trailer socket thing (there is a tow bar) and few relays and fuses dotted about and one flat 4 pin connector sitting there doing nothing (but it's not a blue wire) - so not having a factory head unit, and no module I assume this would maybe be an expensive "toy" that I can do without - just something I can add to my "wish list" then |
21st Sep 2015 10:20am |
You won't have the blue wire. That is a 'home made' antenna in lieu of the correct one. However having recently fitted Paul's module I can vouch for its effectiveness.
21st Sep 2015 10:40am |
Steveo Member Since: 26 Jan 2015 Location: Essex Posts: 156 |
Good evening all please excuse me but being a ex paratrooper we are not known for having a large amount of brain cells I have got a 2004 td6 and I have been looking to see if I have a fbh after looking at this post but the only setting I can find is AUX vent and a little red fan comes on is this the fbh or do I need to have it switched on at dealers ect regards Steve |
21st Sep 2015 6:46pm |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
easy way of finding out if park heating is available to you is
22nd Sep 2015 10:10am |
