![]() | Home > Wheels & Tyres > 305 40 22 |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
No personal experience but see tyre size options on 22s thread below on this page, it looks like these would rub on your wheel arches. Only Range Rovers since 1988 |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7998 ![]() ![]() ![]() |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
They will rub sir... I have 275.40.22 and have been advised 285.40.22 also work very well... |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
& cue gratuitous picture of 305/40R22 tyre!! (Side tubes now removed
Craig is correct - they can rub a tad with suspension compression and you need a heat gun to deform the rear wheel arch liner where it goes around the filler tube. The rears have 6mm spacers fitted but I don't they are necessary and removing them may help to reduce compression rubbing. The fronts also just touch the wheel arch liner vents when on big lock ![]() However, I'll definately be fitting the same size again if I stick to 22s - I like big rubber with big wheels ![]() ![]() |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
cue broken record....
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 761 ![]() ![]() ![]() |
As per my post that was linked too, I ended up getting 285/40x22 recently and the improvement over ride quality over the old 285/35's you wouldnt believe!
IanT599 Member Since: 15 Jun 2013 Location: Wellington Posts: 351 ![]() ![]() |
Are you running spacers on your car due to the tyre width? |
you're welcome ![]() 2008 FFRR (sold) 2008 BMW M5 |
