Home > Wheels & Tyres > 305 40 22
abs123
United Kingdom 2004 Range Rover Vogue Td6 Java Black
305 40 22
I'm looking to get a set of 22" alloy wheels for my car and am considering a different tyre size.
I was looking at 305 40 22 rather than the standard 285 35 22
Can anyone foresee an problems with that setup?
Has it been done before? If so any pics would be great?
Thanks
Post #347403 12th Sep 2015 4:02pm
CS
No personal experience but see tyre size options on 22s thread below on this page, it looks like these would rub on your wheel arches. Only Range Rovers since 1988
Post #347405 12th Sep 2015 4:08pm
http://www.fullfatrr.com/forum/topic31757.html
Post #347414 12th Sep 2015 4:49pm
They will rub sir... I have 275.40.22 and have been advised 285.40.22 also work very well...
Post #347450 12th Sep 2015 7:20pm
RiccartonRR
& cue gratuitous picture of 305/40R22 tyre!! (Side tubes now removed Thumbs Up Thumbs Up )
Craig is correct - they can rub a tad with suspension compression and you need a heat gun to deform the rear wheel arch liner where it goes around the filler tube. The rears have 6mm spacers fitted but I don't they are necessary and removing them may help to reduce compression rubbing. The fronts also just touch the wheel arch liner vents when on big lock Shocked
However, I'll definately be fitting the same size again if I stick to 22s - I like big rubber with big wheels Thumbs Up Thumbs Up
Post #347454 12th Sep 2015 7:39pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
cue broken record....
285/40/22...get them
Very Happy 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #347675 14th Sep 2015 1:21pm
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
As per my post that was linked too, I ended up getting 285/40x22 recently and the improvement over ride quality over the old 285/35's you wouldnt believe!
Totally transformed the ride quality, you might struggle to get much of a selection of tyre brands, I hunted high and low and found 3 or 4 maximum, ranging from £100 per corner for a budget tyre (allegedy imported or made by a more famous brand) or Conti's for about £250 a piece
Very impressed with the size and will definately stick to these. I did look at the 305/40 originally as I found some well known brands for I think £100-£120 a piece, but the rubbing/wheel arch mods others speak of put me off
Post #348479 19th Sep 2015 5:10am
Post #348510 19th Sep 2015 10:03am
IanT599
Are you running spacers on your car due to the tyre width?
Post #348549 19th Sep 2015 6:14pm
horse86
you're welcome Wink 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #349930 29th Sep 2015 1:22pm
