Home > Technical (L322) > TDV8 Turbos
Page 5 of 5 <12345
Baben
South Africa 2014 Range Rover Autobiography SDV8 Luxor
Cam-Tech-Craig wrote:
Mikey wrote:
In light of these actual EGT readings, it seems prudent to quote myself from the previous page, just to remind ourselves... Thumbs Up
If you were running a race car into the pits then YES that statement is correct but ITS A TDi RANGE ROVER FFS! Who in there right mind is going to sit there and let the car tick over for 10 mins beginning & ending of every journey! Do RR owners not have better, more important things to do with their lives? Rolling Eyes
And we are not talking about 10 minutes of idling. We are talking 60-90 seconds
Nonsense! As that info states the temps take upto 15secs to reach acceptable levels after a 160kph “fast” run! It takes longer than 15secs to drive up most slip roads exiting motorways! Therefore negating the need to “rest” turbo’s on modern diesels.
Craig, the results I posted were driving all the time. To recover from 700 to 200 in 15 seconds was while coasting at 140+ (kmh)
Hang on I will go for a drive and post a video for you to see what happens
Post #345454 1st Sep 2015 11:10am
Mikey
So then Craig, do tell us
How long does it take for the cast manifolds and turbo body to cool down?
Just because the EGTs have dropped that quickly, doesn't mean the residual heat will drop that quickly. And it's the residual heat that does the damage Banging Head
Post #345481 1st Sep 2015 1:08pm
Baben
On the long road today with the wife driving so I have time to take measurements.
With the current setup (big cooler, coated manifolds,remapped for 610nm on the wheels) cruising at a steady 130kph
(Ignore the rest of the readings apart from the voltage and ambient temp, nothing else but EGT is connected)
At a steady 160kph it's 450C Smile not bad methinks.
So the big argument is about how long it takes to cool down when we stop. We will be pulling in from cruising at 130 into a service area and will time how long it takes to get down to 200C. Watch this space
Post #348373 18th Sep 2015 11:46am
Baben
Took 2 minutes 40 seconds to cool down from about 350 to 200
Post #348377 18th Sep 2015 11:51am
fisha
Egt and cool down has long been talked about in turbos and I do subscribe to the idea of backing off on the last couple of miles to ease the turbo temps down.
That being said, going back to the original post, what is it that's causing the fails that are giving the 3.6 its reputation? An early comment was more likely the actuators failling.... Why are they failing? is it cause of heat soak after switch off or cause of heat build up during use?
If it's during use then cool down is a mute point possibly, and is there anything that could be done to assist cooling ( or heat dissipation) during use? Complete ransom thought but does the engine cover prevent cooling and promote hear buildup? V8 or else ...
Post #349319 24th Sep 2015 9:01pm
Page 5 of 5 <12345
